wafl.nfsv4 events
Creating your file...
Your file is ready
wafl.nfsv4.acl.not.mapped
- Severity
ERROR
- Description
This message occurs when the system cannot map an ID stored in the Access Control Entry (ACE) to a valid UNIX® User ID/Group ID (UID/GID) pair. This failure makes this ACE an invalid one, resulting in a possible loss of access to the file or directory for which this ACE was set.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
ID in NFS Access Control Entry (ACE) on inode number %x, file system ID %x could not be mapped to a user or group. Possible loss of access can result.
- Parameters
inum (INT): Inode number.
fsid (INT): File system ID.
