      san.fcadapter events
san.fcadapter.init.failure
- Severity
ERROR
 - Description
This message occurs when FC adapters hosting LIFs fails to initialize during node boot.
 - Corrective Action
Reboot the affected node. If the problem persists, contact NetApp technical support.
 - Syslog Message
The following FC adapters with configured LIFs failed to initialize: %s.
 - Parameters
adapters (STRING): List of FC adapters that failed to initialize.
object_type (STRING): Type of resource object under notification. For this EMS, the object_type will always be NODE.
object_uuid (STRING): UUID of the resource object. For this EMS, the UUID will be of the node.
