san.fcadapter events
san.fcadapter.init.failure
Severity
ERROR
This message occurs when FC adapters hosting LIFs fails to initialize during node boot.
Corrective Action
Reboot the affected node. If the problem persists, contact NetApp technical support.
Syslog Message
The following FC adapters with configured LIFs failed to initialize: %s.
adapters (STRING): List of FC adapters that failed to initialize.
object_type (STRING): Type of resource object under notification. For this EMS, the object_type will always be NODE.
object_uuid (STRING): UUID of the resource object. For this EMS, the UUID will be of the node.
