san.fcadapter events
Creating your file...
Your file is ready
san.fcadapter.init.failure
- Severity
ERROR
- Description
This message occurs when FC adapters hosting LIFs fails to initialize during node boot.
- Corrective Action
Reboot the affected node. If the problem persists, contact NetApp technical support.
- Syslog Message
The following FC adapters with configured LIFs failed to initialize: %s.
- Parameters
adapters (STRING): List of FC adapters that failed to initialize.
object_type (STRING): Type of resource object under notification. For this EMS, the object_type will always be NODE.
object_uuid (STRING): UUID of the resource object. For this EMS, the UUID will be of the node.
