ONTAP EMS reference
fmmb.current events
fmmb.current EMS events occur when HA mailbox disks are discovered or allocated.
fmmb.current.lock.disk
Severity
INFORMATIONAL
This event is issued when HA mailbox disks are discovered or allocated.
Corrective Action
(None).
Syslog Message
Disk %s is a %s HA mailbox disk.
disk (STRING): The name of the disk. If the disk name is not available, the name ?.? will be used.
host (STRING): The node which owns the HA mailbox disk. The node can be either local or partner.
