The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
unowned.disk events
Creating your file...
Your file is ready
unowned.disk.reminder
- Severity
INFORMATIONAL
- Description
This message occurs when the system has unowned/unassigned disks. Use the "disk assign" command to assign the disks to the systems so that they can be used.
- Corrective Action
Use 'disk show -n' to determine which disks are unowned. Use 'disk assign' to assign ownership of the disks to a system.
- Syslog Message
%d disks are currently unowned. Use the "disk assign" command to assign the disks to a system.
- Parameters
count (INT): Number of unowned disks.
