unowned.disk events
unowned.disk EMS events occur when the system has unowned/unassigned disks.
unowned.disk.reminder
- Severity
INFORMATIONAL
- Description
This message occurs when the system has unowned/unassigned disks. Use the "disk assign" command to assign the disks to the systems so that they can be used.
- Corrective Action
Use 'disk show -n' to determine which disks are unowned. Use 'disk assign' to assign ownership of the disks to a system.
- Syslog Message
%d disks are currently unowned. Use the "disk assign" command to assign the disks to a system.
- Parameters
count (INT): Number of unowned disks.
