The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
config.badslot events
Creating your file...
Your file is ready
config.BadSlot
- Severity
ALERT
- Description
This message occurs when a disk is found to be attached to an invalid Host Adapter (HA) controller slot.
- Corrective Action
Consult the NetApp technical support guides for the supported slots for adapters in the hardware platform. If the adapter is in a supported slot, contact NetApp technical support for further assistance.
- Syslog Message
Disk %s is attached to an invalid HA slot. This is an illegal configuration.
- Parameters
disk (STRING): Name of the disk.
