ONTAP EMS reference
smbc.aufo events
smbc.aufo EMS events occur when ONTAP encounters issues associated with SnapMirror® active sync automatic unplanned failover operations.
smbc.aufo.completed
Severity
NOTICE
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation completes.
Corrective Action
(None).
Syslog Message
SnapMirror automatic failover completed. Destination path: %s.
dstpath (STRING): Path name of the destination group of the SMBC relationship.
smbc.aufo.failed
Severity
ERROR
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation fails.
Corrective Action
Perform "snapmirror delete -destination-path destination_path" followed by "snapmirror break" on the volumes.
Syslog Message
SnapMirror automatic failover failed. Destination path: %s.
smbc.aufo.failover.incapable
Severity
ERROR
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation fails because the destination site is not failover capable.
Corrective Action
Before applying corrective action, the User must ensure that the primary/master copy is unavailable, otherwise the assumption is that Master copy is actively being used by the Application workload. Perform "snapmirror delete -destination-path destination_path" followed by "snapmirror break" on the volumes.
Syslog Message
SnapMirror automatic failover encountered a failure because the site with destination path "%s" is not failover-capable.
smbc.aufo.queued
Severity
NOTICE
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation is queued.
Corrective Action
(None).
Syslog Message
SnapMirror Business Continuity (SMBC) automatic unplanned operation failover queued. Destination path: %s.
smbc.aufo.start
Severity
NOTICE
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation starts.
Corrective Action
(None).
Syslog Message
SnapMirror automatic failover started. Destination path: %s.
