ONTAP EMS reference
netif.phyread events
netif.phyread EMS events occur when there is a failure in reading the physical layer (PHY) of a network interface.
netif.phyRead
Severity
ERROR
This message occurs when there is a failure in reading the physical layer (PHY) of a network interface.
Corrective Action
This might be caused by a software bug. If there are problems with the interface after seeing this message, contact NetApp technical support.
Syslog Message
Failure in reading PHY for network interface %s.
ifName (STRING): Name of the network interface; for example, "e8a".
