ONTAP EMS reference
replication.qtree events
replication.qtree EMS events occur when ONTAP encounters issues associated with disk errors during qtree replication.
replication.qtree.dst.disk.error
Severity
ALERT
This message occurs when the replication destination engine receives blocks with disk errors from the source for the first time in a transfer and continues with replication.
Corrective Action
Contact NetApp technical support.
Syslog Message
SnapMirror: transfer from %s:%s to %s:%s: Source volume has disk errors. Continuing with replication. See /etc/log/snapmirror for inconsistency details.
src_filer (STRING): Source filer of this replication transfer.
src_path (STRING): Source path of this replication transfer.
dst_filer (STRING): Destination filer of this replication transfer.
dst_path (STRING): Destination path of this replication transfer.
replication.qtree.dst.disk.error.abort
Severity
ERROR
This message occurs when the replication destination engine receives blocks with disk errors from the source and aborts because of user-set options.
Corrective Action
Syslog Message
SnapMirror: transfer from %s:%s to %s:%s: Source volume has disk errors. (source fid:%u,source fbn:%u,source snapid:%u). Aborting transfer.
sfileid (INT): Identifying number for the suspect file
sfbn (INT): File block number in which the disk error was found.
ssnapid (INT): Incremental Snapshot(tm) copy of the source from which this file came.
replication.qtree.dst.disk.error.summary
Severity
ERROR
This message occurs when the replication involving blocks with disk errors happens on the replication destination.
Corrective Action
Syslog Message
SnapMirror: transfer from %s:%s to %s:%s: Source volume has disk errors. %u blocks out of %u blocks replicated are inconsistent. See /etc/log/snapmirror for inconsistency details.
total_bad_blks (INT): Total number of blocks with disk errors received.
total_blks (INT): Total number of blocks received.
replication.qtree.dst.inconsistent.acl
Severity
ERROR
This message occurs when the replication destination engine receives an Access Control List (ACL) with disk errors from the source.
Corrective Action
Syslog Message
SnapMirror: transfer from %s:%s to %s:%s: Source volume has disk errors. (source acl fid:%u,source snapid:%u). Aborting transfer.
sfileid (INT): Identifying number for the suspect ACL.
snapid (INT): Incremental Snapshot(tm) copy of the source from which this ACL came.
Severity
ERROR
This message occurs when the replication destination engine receives a symbolic link with disk errors from the source.
Corrective Action
Syslog Message
SnapMirror: transfer from %s:%s to %s:%s: Source volume has disk errors. (source symlink fid:%u,source snapid:%u). Aborting transfer.
sfileid (INT): Identifying number for the suspect symbolic link.
snapid (INT): Incremental Snapshot(tm) copy of the source from which this symbolic link came.
