replication.qtree events
Creating your file...
replication.qtree.dst.disk.error
- Severity
ALERT
- Description
This message occurs when the replication destination engine receives blocks with disk errors from the source for the first time in a transfer and continues with replication.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
SnapMirror: transfer from %s:%s to %s:%s: Source volume has disk errors. Continuing with replication. See /etc/log/snapmirror for inconsistency details.
- Parameters
src_filer (STRING): Source filer of this replication transfer.
src_path (STRING): Source path of this replication transfer.
dst_filer (STRING): Destination filer of this replication transfer.
dst_path (STRING): Destination path of this replication transfer.
replication.qtree.dst.disk.error.abort
- Severity
ERROR
- Description
This message occurs when the replication destination engine receives blocks with disk errors from the source and aborts because of user-set options.
- Corrective Action
- Syslog Message
SnapMirror: transfer from %s:%s to %s:%s: Source volume has disk errors. (source fid:%u,source fbn:%u,source snapid:%u). Aborting transfer.
- Parameters
sfileid (INT): Identifying number for the suspect file
sfbn (INT): File block number in which the disk error was found.
ssnapid (INT): Incremental Snapshot(tm) copy of the source from which this file came.
replication.qtree.dst.disk.error.summary
- Severity
ERROR
- Description
This message occurs when the replication involving blocks with disk errors happens on the replication destination.
- Corrective Action
- Syslog Message
SnapMirror: transfer from %s:%s to %s:%s: Source volume has disk errors. %u blocks out of %u blocks replicated are inconsistent. See /etc/log/snapmirror for inconsistency details.
- Parameters
total_bad_blks (INT): Total number of blocks with disk errors received.
total_blks (INT): Total number of blocks received.
replication.qtree.dst.inconsistent.acl
- Severity
ERROR
- Description
This message occurs when the replication destination engine receives an Access Control List (ACL) with disk errors from the source.
- Corrective Action
- Syslog Message
SnapMirror: transfer from %s:%s to %s:%s: Source volume has disk errors. (source acl fid:%u,source snapid:%u). Aborting transfer.
- Parameters
sfileid (INT): Identifying number for the suspect ACL.
snapid (INT): Incremental Snapshot(tm) copy of the source from which this ACL came.
replication.qtree.dst.inconsistent.symlink
- Severity
ERROR
- Description
This message occurs when the replication destination engine receives a symbolic link with disk errors from the source.
- Corrective Action
- Syslog Message
SnapMirror: transfer from %s:%s to %s:%s: Source volume has disk errors. (source symlink fid:%u,source snapid:%u). Aborting transfer.
- Parameters
sfileid (INT): Identifying number for the suspect symbolic link.
snapid (INT): Incremental Snapshot(tm) copy of the source from which this symbolic link came.
