wafl.gs events
Creating your file...
wafl.gs.metafile.load.failed
- Severity
ERROR
- Description
This message occurs when wafl is unsuccessful to check and load Granular Set metafile for the volume.
- Corrective Action
Issue volume offline followed by volume online and confirm this error message does not happen again. For more information or assistance, contact NetApp technical support.
- Syslog Message
Wafl failed to load metafile that stores wafl copy of SnapMirror CG.
- Parameters
volume (STRING): Volume name.
error (INT): Error code.
wafl.gs.modify.op.failed
- Severity
NOTICE
- Description
This message occurs when WAFL® prohibits loading a file for a modify operation on a read-only consistency group.
- Corrective Action
NONE.
- Syslog Message
Failed to load file ID %u on volume %s%s%s%s FSID:%u for a modify operation because it is part of a read-only sync relationship.
- Parameters
fileid (INT): File identifier.
volowner (STRING): Owner of the volume.
volname (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient. Consists of the Vserver name and UUID.
fsid (INT): File system ID of the volume.
wafl.gs.remove.rename.op.failed
- Severity
NOTICE
- Description
This message occurs when WAFL® prohibits a rename operation or an unlink operation on a file part of a consistency group.
- Corrective Action
NONE.
- Syslog Message
Failed to load file ID %u on volume %s%s%s%s FSID:%u for a rename operation or an unlink operation because it is part of a sync relationship.
- Parameters
wafl.gs.resync.gen.check.failed
- Severity
NOTICE
- Description
This message occurs when WAFL® prohibits modification to a file that is part of a consistency group and the operation does not have the right generation enforcement parameters. This can occur if the operation happened before the SnapMirror® relationship was established.
- Corrective Action
NONE.
- Syslog Message
Unexpected operation on consistency group file ID %u on volume %s%s%s%s FSID:%u. This can occur if the operation happened before the SnapMirror relationship was established.
- Parameters
