disk.ioreassignfailed events
disk.ioReassignFailed
- Severity
ALERT
- Description
This message occurs when a disk reports a medium error and the sector reassignment fails. The system will fail the disk after possible recovery of retrieviable disk data.
- Corrective Action
Replace the disk when the system indicates that you should remove it in subsequent logged events.
- Syslog Message
disk %s: sector %llu failed to be reassigned (%d). %s
- Parameters
diskName (STRING): Name of the disk.
sector (LONGINT): Sector where the error was detected.
ETime (INT): Time, in milliseconds, from when the command was first issued until this I/O operation failed.
disk_information (STRING): Formatted information about the disk. This includes the disk's vendor, model, firmware revision, and serial number.
