The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
connectx.fatalerror events
Creating your file...
Your file is ready
connectx.fatalError
- Severity
ERROR
- Description
This message occurs when a fatal error is polled from the ConnectX(tm) InfiniBand® adapter. Controller failover will be disabled.
- Corrective Action
Contact NetApp technical support. ConnectX registers have been dumped to the /etc/mlxlog/ConnectX_regdump file.
- Syslog Message
HA interconnect HBA failure, ConnectX fatal error was polled.
- Parameters
(None).
