The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
haosc.sa events
Creating your file...
Your file is ready
haosc.sa.config
- Severity
ERROR
- Description
This message occurs when nonvolatile memory on a stand-alone system is configured for a high-availability system. Only half of the available nonvolatile memory will be used and system performance will be affected.
- Corrective Action
Reboot the system to use all of the nonvolatile memory.
- Syslog Message
Only half of the available nonvolatile memory is in use. This will affect system performance.
- Parameters
(None).
