The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
aggr.inconsistent events
Creating your file...
Your file is ready
aggr.inconsistent.modify
- Severity
INFORMATIONAL
- Description
This message occurs when the 'aggr inconsistent' command is used to modify a state of an aggregate.
- Corrective Action
(None).
- Syslog Message
Aggregate %s: 'aggr inconsistent' command used to change inconsistent state to '%s'.
- Parameters
aggr (STRING): Name of the aggregate.
state (STRING): State of the action: "set" or "clear".
