The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
rsh.rcmd events
Creating your file...
Your file is ready
rsh.rcmd.port.bind
- Severity
ERROR
- Description
This message occurs when there is an error in binding a reserved port.
- Corrective Action
(None).
- Syslog Message
rcmd.c: Bind error %d on reserved port %d.
- Parameters
errNum (INT): Error number.
port (INT): Port number.
rsh.rcmd.port.used
- Severity
ERROR
- Description
This message occurs when there is no port available for binding to a socket, because all the reserved ports are in use.
- Corrective Action
(None).
- Syslog Message
rcmd.c: All reserved ports have been used.
- Parameters
(None).
