ONTAP EMS reference
rsh.rcmd events
rsh.rcmd EMS events occur when ONTAP encounters issues associated with reserved port binding operations.
rsh.rcmd.port.bind
Severity
ERROR
This message occurs when there is an error in binding a reserved port.
Corrective Action
(None).
Syslog Message
rcmd.c: Bind error %d on reserved port %d.
errNum (INT): Error number.
port (INT): Port number.
rsh.rcmd.port.used
Severity
ERROR
This message occurs when there is no port available for binding to a socket, because all the reserved ports are in use.
Corrective Action
(None).
Syslog Message
rcmd.c: All reserved ports have been used.
(None).
