rsh.rcmd events
Creating your file...
Your file is ready
rsh.rcmd.port.bind
- Severity
ERROR
- Description
This message occurs when there is an error in binding a reserved port.
- Corrective Action
(None).
- Syslog Message
rcmd.c: Bind error %d on reserved port %d.
- Parameters
errNum (INT): Error number.
port (INT): Port number.
rsh.rcmd.port.used
- Severity
ERROR
- Description
This message occurs when there is no port available for binding to a socket, because all the reserved ports are in use.
- Corrective Action
(None).
- Syslog Message
rcmd.c: All reserved ports have been used.
- Parameters
(None).
