useradmin.registry events
useradmin.registry
- Severity
ERROR
 - Description
This message occurs when the system encounters an internal registry error while reading the useradmin entries.
 - Corrective Action
If the error persists, contact NetApp technical support for further assistance.
 - Syslog Message
A general registry error occurred when %s.
 - Parameters
operation (STRING): Operation in execution when the registry error occurred.
useradmin.registry.specific
- Severity
ERROR
 - Description
This message occurs when the system encounters an internal registry error while reading/writing a specific useradmin entry for a specific user.
 - Corrective Action
Try to delete and re-create the user/group/role. If this is does not work, then you may have to modify the registry directly.
 - Syslog Message
A general registry error occurred during a %s for %s: '%s'.
 - Parameters
type (STRING): The type of name which is the source of the error. This can be one of the following values: "user", "group", "role", or "capability".
name (STRING): The name of the subject which is the source of the error.
