ONTAP EMS reference
useradmin.registry events
useradmin.registry EMS events occur when ONTAP encounters issues associated with the useradmin registry.
useradmin.registry
Severity
ERROR
This message occurs when the system encounters an internal registry error while reading the useradmin entries.
Corrective Action
If the error persists, contact NetApp technical support for further assistance.
Syslog Message
A general registry error occurred when %s.
operation (STRING): Operation in execution when the registry error occurred.
useradmin.registry.specific
Severity
ERROR
This message occurs when the system encounters an internal registry error while reading/writing a specific useradmin entry for a specific user.
Corrective Action
Try to delete and re-create the user/group/role. If this is does not work, then you may have to modify the registry directly.
Syslog Message
A general registry error occurred during a %s for %s: '%s'.
type (STRING): The type of name which is the source of the error. This can be one of the following values: "user", "group", "role", or "capability".
name (STRING): The name of the subject which is the source of the error.
