encryption.queue events
encryption.queue.op.failed
Severity
ERROR
This message occurs when an operation on the volume in the encryption queue failed.
Corrective Action
Check the reason for the failure included in the message. Correct the issue and try the operation again.
Syslog Message
%s operation failed on the queued volume '%s' in Vserver '%s'. Reason: %s.
op (STRING): Conversion operation.
volumename (STRING): Name of the volume.
vservername (STRING): Name of the Vserver.
reason (STRING): Reason for the failure.
