ONTAP EMS reference
hypervisor.memory events
hypervisor.memory EMS events occur when the amount of memory installed on the hypervisor is not sufficient for ONTAP® Select support.
hypervisor.memory.size
Severity
ALERT
This message occurs when the amount of memory installed on the hypervisor is not sufficient for ONTAP® Select support.
Corrective Action
Add more memory to the ONTAP® Select hypervisor configuration.
Syslog Message
Insufficient amount of memory on the hypervisor: %s. ONTAP® Select requires: %s of memory.
size (STRING): Size of memory active on the hypervisor.
required (STRING): Size of memory required on the hypervisor.
