config.atanotsupported events
config.ATAnotSupported
- Severity
ERROR
- Description
This message occurs when an ATA disk is found, but the appliance does not support it.
- Corrective Action
Remove the ATA disks or upgrade your appliance to a model that supports ATA disks. Check your support provider's web site or knowledgebase for more information about appliance models that support ATA disks.
- Syslog Message
ATA disks are not supported on this appliance. Disk %s is an ATA disk and should be removed.
- Parameters
disk (STRING): Name of the disk.
