ONTAP EMS reference
diskshelf.psu events
diskshelf.psu EMS events occur when ONTAP encounters issues associated with disk shelf power supply units.
diskShelf.psu.added
Severity
NOTICE
This message occurs when a power supply unit is added to the disk shelf.
Corrective Action
(None).
Syslog Message
%s power supply was added to %s.shelf%d
location (STRING): Which power supply was added.
channelName (STRING): Channel connected to disk shelf.
shelfIdent (INT): ID number displayed on the disk shelf OPS panel.
serialNumber (STRING): Serial number of disk shelf.
diskShelf.psu.removed
Severity
ERROR
This message occurs when a power supply unit is removed from the disk shelf.
Corrective Action
Insert a functional power supply unit into the disk shelf.
Syslog Message
%s power supply was removed from %s.shelf%d
location (STRING): Which power supply was removed.
