ONTAP EMS reference
virtual.limits events
virtual.limits.disabled
Severity
INFORMATIONAL
This message occurs when the process virtual memory limit calculations are disabled on a given node. The virtual memory calculations are explicitly disabled by setting the boot argument "bootarg.engage_vss_limit=false".
Corrective Action
(None).
Syslog Message
Virtual memory limit calculations are disabled on node %s.
node (STRING): Name of the node where the calculations are disabled.
virtual.limits.proc
Severity
INFORMATIONAL
This message occurs when the process virtual limit is overridden by the /mroot/etc/cluster_config/vsz_override file. An entry in this file indicates that the default virtual size of a process needed to be overridden.
Corrective Action
(None).
Syslog Message
Virtual memory limit for process %s on node %s overridden to %llu.
process (STRING): Process that required the override
node (STRING): Node name where the file was updated.
size (LONGINT): New virtual size, in bytes.
