The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cmds.software events
Creating your file...
Your file is ready
cmds.software.dirErr
- Severity
ERROR
- Description
This message occurs because the system cannot create the directory at the designated path.
- Corrective Action
(None).
- Syslog Message
Could not create directory %s: %s
- Parameters
path (STRING): Path where directory was supposed to be created.
errorMsg (STRING): Error message.
cmds.software.installDone
- Severity
INFORMATIONAL
- Description
This message occurs during software update and installation to inform you that the installation is complete.
- Corrective Action
(None).
- Syslog Message
Software: Installation of %s was completed.
- Parameters
fileName (STRING): Name of the file to be updated/installed.
cmds.software.installNotDone
- Severity
INFORMATIONAL
- Description
This message occurs during software update and installation to inform you that installation failed.
- Corrective Action
(None).
- Syslog Message
Software: Installation of %s failed.
- Parameters
