ONTAP EMS reference
cmds.software events
cmds.software EMS events occur when ONTAP encounters issues associated with software installation operations.
cmds.software.dirErr
Severity
ERROR
This message occurs because the system cannot create the directory at the designated path.
Corrective Action
(None).
Syslog Message
Could not create directory %s: %s
path (STRING): Path where directory was supposed to be created.
errorMsg (STRING): Error message.
cmds.software.installDone
Severity
INFORMATIONAL
This message occurs during software update and installation to inform you that the installation is complete.
Corrective Action
(None).
Syslog Message
Software: Installation of %s was completed.
fileName (STRING): Name of the file to be updated/installed.
cmds.software.installNotDone
Severity
INFORMATIONAL
This message occurs during software update and installation to inform you that installation failed.
Corrective Action
(None).
Syslog Message
Software: Installation of %s failed.
