      cmds.software events
cmds.software.dirErr
- Severity
ERROR
 - Description
This message occurs because the system cannot create the directory at the designated path.
 - Corrective Action
(None).
 - Syslog Message
Could not create directory %s: %s
 - Parameters
path (STRING): Path where directory was supposed to be created.
errorMsg (STRING): Error message.
cmds.software.installDone
- Severity
INFORMATIONAL
 - Description
This message occurs during software update and installation to inform you that the installation is complete.
 - Corrective Action
(None).
 - Syslog Message
Software: Installation of %s was completed.
 - Parameters
fileName (STRING): Name of the file to be updated/installed.
cmds.software.installNotDone
- Severity
INFORMATIONAL
 - Description
This message occurs during software update and installation to inform you that installation failed.
 - Corrective Action
(None).
 - Syslog Message
Software: Installation of %s failed.
 - Parameters
