cmds.software events
cmds.software EMS events occur when ONTAP encounters issues associated with software installation operations.
cmds.software.dirErr
- Severity
ERROR
- Description
This message occurs because the system cannot create the directory at the designated path.
- Corrective Action
(None).
- Syslog Message
Could not create directory %s: %s
- Parameters
path (STRING): Path where directory was supposed to be created.
errorMsg (STRING): Error message.
cmds.software.installDone
- Severity
INFORMATIONAL
- Description
This message occurs during software update and installation to inform you that the installation is complete.
- Corrective Action
(None).
- Syslog Message
Software: Installation of %s was completed.
- Parameters
fileName (STRING): Name of the file to be updated/installed.
cmds.software.installNotDone
- Severity
INFORMATIONAL
- Description
This message occurs during software update and installation to inform you that installation failed.
- Corrective Action
(None).
- Syslog Message
Software: Installation of %s failed.
- Parameters
