mgr.stack events
mgr.stack EMS events occur when ONTAP encounters issues associated with panic information.
mgr.stack.at
- Severity
NOTICE
- Description
This message contains the panic string.
- Corrective Action
(None).
- Syslog Message
Panic occurred at: %s
- Parameters
time (STRING): The time string
mgr.stack.checkpoint
- Severity
NOTICE
- Description
Logs the last checkpoint dumpcore crossed before failing.
- Corrective Action
(None).
- Syslog Message
Dumpcore failure: At checkpoint %d
- Parameters
checkpoint (INT): (None).
mgr.stack.frame
- Severity
NOTICE
- Description
The stack frame: frame number, functionname, base, offset.
- Corrective Action
(None).
- Syslog Message
Stack frame %2d: %s(0x%llx) + 0x%x
- Parameters
frame (INT): The frame number
sym (STRING): The symbolic name
base (PTR): The base address
offset (INTHEX): The offset
mgr.stack.frameaddr
- Severity
NOTICE
- Description
The stack frame: frame number, (no function name), base, offset.
- Corrective Action
(None).
- Syslog Message
Stack frame %2d: 0x%llx + 0x%x
- Parameters
mgr.stack.framebase
- Severity
NOTICE
- Description
The stack frame: frame number, base address.
- Corrective Action
(None).
- Syslog Message
- Parameters
mgr.stack.longrun.proc
- Severity
NOTICE
- Description
The name of the process that hogged the cpu too long.
- Corrective Action
(None).
- Syslog Message
Long running process: %s
- Parameters
name (STRING): The name of the process
mgr.stack.noFrames
- Severity
NOTICE
- Description
This message is emitted when no stack frames are available. This is normal on platforms which do not support stack tracing, or when the prior release did not support stack trace.
- Corrective Action
(None).
- Syslog Message
No stack frames available
- Parameters
(None).
mgr.stack.proc
- Severity
NOTICE
- Description
The name of the process that we took the panic in.
- Corrective Action
(None).
- Syslog Message
Panic in process: %s
- Parameters
mgr.stack.saved
- Severity
NOTICE
- Description
This message indicates that we've saved panic information in the NV RAM.
- Corrective Action
(None).
- Syslog Message
Reboot with saved panic information in log file
- Parameters
(None).
mgr.stack.string
- Severity
NOTICE
- Description
- Corrective Action
(None).
- Syslog Message
Panic string: %s
- Parameters
string (STRING): The panic string
