hypervisor.cpu events
hypervisor.cpu.count
- Severity
ALERT
- Description
This message occurs when the number of physical CPUs on the hypervisor are not sufficient for ONTAP® Select support.
- Corrective Action
Add more CPUs to the ONTAP® Select hypervisor configuration.
- Syslog Message
Insufficient number of CPUs on the hypervisor is: %d. ONTAP® Select requires: %d
- Parameters
count (INT): Number of CPUs on the hypervisor.
minimum (INT): Minimum number of CPUs required on the hypervisor.
hypervisor.cpu.version
- Severity
ALERT
- Description
This message occurs when the hypervisor CPU type running ONTAP® Select is not supported. Supported types are the XEON E5 v3 or later.
- Corrective Action
Move ONTAP® Select to a hypervisor with a supported CPU.
- Syslog Message
Unsupported hypervisor CPU: %s
- Parameters
version (STRING): Current version of the CPU.
