The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
netif.speednotsupported events
Creating your file...
Your file is ready
netif.speedNotSupported
- Severity
ERROR
- Description
This message occurs when a network interface autonegotiates to an unsupported speed.
- Corrective Action
Connect to 1 or 10 gigabits per second (Gbps) switch port.
- Syslog Message
Autonegotiation on network interface %s resolved to speed %d. This speed is not supported.
- Parameters
ifname (STRING): Name of network interface.
speed (INT): Speed in megabits per second (Mbps).
