fc.bridge events
Creating your file...
fc.bridge.fc.port.alert
- Severity
ALERT
- Description
This message occurs when an FC port goes offline.
- Corrective Action
Check cables, SFPs, and connected devices. If the port is intentionally unused, use the Fibre Channel bridge CLI to disable it.
- Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s FC Port FC_PORT%d offline. %s
- Parameters
bridgeType (STRING): Type of the FC-to-SAS bridge.
bridgeName (STRING): Name of the FC-to-SAS bridge.
bridgeSerialNum (STRING): Serial number of the FC-to-SAS bridge.
bridgeWWN (STRING): World-Wide Name (WWN) of the FC-to-SAS bridge.
bridgePort (INT): Port reported by the FC-to-SAS bridge.
addlInfo (STRING): Additional information about the alert being generated, if available.
fc.bridge.fc.port.notice
- Severity
NOTICE
- Description
This message occurs when an FC port on the identified bridge comes online.
- Corrective Action
(None).
- Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s FC Port FC_PORT%d connected. %s
- Parameters
fc.bridge.power.alert
- Severity
ALERT
- Description
This message occurs when an FC-to-SAS bridge power supply fails.
- Corrective Action
Check input power and cable. If the problem persists, replace the power supply.
- Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s Power Supply %s has failed. %s
- Parameters
bridgePowerSupply (STRING): Power supply reported by the FC-to-SAS bridge.
fc.bridge.power.notice
- Severity
NOTICE
- Description
This message occurs when an FC-to-SAS bridge power supply returns to normal operation.
- Corrective Action
(None).
- Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s Power supply %s operating normally. %s
- Parameters
bridgePowerSupply (STRING): Port reported by the FC-to-SAS bridge.
fc.bridge.sas.phy.alert
- Severity
ALERT
- Description
This message occurs when a SAS port PHY goes offline.
- Corrective Action
Check Mini-SAS HD connector, cables, and connected equipment.
- Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s SAS Port %d Phy %d offline. %s
- Parameters
bridgePhy (INT): SAS port Phy reported by the FC-to-SAS bridge.
fc.bridge.sas.phy.notice
- Severity
NOTICE
- Description
This message occurs when a SAS port PHY on a bridge comes online.
- Corrective Action
(None).
- Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s SAS port %d Phy %d online. %s
- Parameters
bridgePhy (INT): Phy reported by the FC—to-SAS bridge.
fc.bridge.sas.port.alert
- Severity
ALERT
- Description
This message occurs when an SAS port goes offline.
- Corrective Action
- Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s SAS Port SAS_PORT%d offline. %s
- Parameters
fc.bridge.sas.port.notice
- Severity
NOTICE
- Description
This message occurs when an SAS port on the identified bridge comes online.
- Corrective Action
(None).
- Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s SAS Port SAS_PORT%d connected. %s
- Parameters
fc.bridge.temp.alert
- Severity
ALERT
- Description
This message occurs when an FC-to-SAS bridge reaches a elevated temperature threshold. The bridge will continue to operate, but action should be taken to reduce the temperature.
- Corrective Action
The bridge is experiencing an elevated temperature, which indicates a loss of cooling airflow. Check cooling airflow, fan operation, and ambient temperature, and take action to reduce the FC-to-SAS bridge operating temperature. If this is not done and the temperature continues to rise, the FC-to-SAS bridge will shut down when the critical temperature threshold is reached.
- Syslog Message
FC-to-SAS %s bridge with name: %s S/N: %s WWN: %s is operating at elevated temperature (%d C). %s
- Parameters
bridgeTemp (INT): Temperature reported by the FC-to-SAS bridge.
fc.bridge.temp.emergency
- Severity
EMERGENCY
- Description
This message occurs when an FC-to-SAS bridge reaches a critical temperature threshold. The bridge will shut down to protect the hardware.
- Corrective Action
Take immediate action to reduce the operating temperature of the FC-to-SAS bridge to avoid hardware damage. Check cooling airflow, fan operation, and ambient temperature. The FC-to-SAS bridge will shut down when this condition is reached, and will not operate until the temperature is reduced.
- Syslog Message
FC-to-SAS %s bridge with name: %s S/N: %s WWN:%s has reached critical temperature (%d C) and will soon shut down. %s
- Parameters
fc.bridge.temp.notice
- Severity
NOTICE
- Description
This message occurs when an FC-to-SAS bridge returns to a normal operating temperature. No action needs to be taken, because the FC-to-SAS bridge temperature has returned to normal levels.
- Corrective Action
(None).
- Syslog Message
FC-to-SAS %s bridge %s S/N: %s WWN: %s temperature has returned to normal (%d C). %s
- Parameters
fc.bridge.throughput.alert
- Severity
ALERT
- Description
This message occurs when an FC-to-SAS bridge experiences degraded throughput.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s is experiencing degraded throughput. %s
- Parameters
fc.bridge.throughput.notice
- Severity
NOTICE
- Description
This message occurs when an FC-to-SAS bridge recovers from degraded throughput.
- Corrective Action
(None).
- Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s throughput is normal. %s
- Parameters
