ONTAP EMS reference
nvmeof.portioma events
nvmeof.portioma EMS events occur when ONTAP encounters issues associated with port connections to top module (A) on shelves.
nvmeof.portioma.clear
Severity
NOTICE
This message occurs when there are no longer two ports cabled incorrectly from a node to top module (A) on a shelf.
Corrective Action
(None).
Syslog Message
Two ports are no longer cabled incorrectly from node %s to top module (A) on shelf with SN %s.
node_name (STRING): Host port connected to the cable.
shelf_sn (STRING): Serial number of the shelf connected to the cable.
nvmeof.portioma.error
Severity
ERROR
This message occurs when there are two ports cabled to the top module (A) on a shelf.
Corrective Action
Connect two ports to different modules to provide redundancy.
Syslog Message
There are two ports cabled from node %s to top module (A) on Shelf with SN %s. One of these cables should be removed.
