The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nvmeof.portioma events
Creating your file...
Your file is ready
nvmeof.portioma.clear
- Severity
NOTICE
- Description
This message occurs when there are no longer two ports cabled incorrectly from a node to top module (A) on a shelf.
- Corrective Action
(None).
- Syslog Message
Two ports are no longer cabled incorrectly from node %s to top module (A) on shelf with SN %s.
- Parameters
node_name (STRING): Host port connected to the cable.
shelf_sn (STRING): Serial number of the shelf connected to the cable.
nvmeof.portioma.error
- Severity
ERROR
- Description
This message occurs when there are two ports cabled to the top module (A) on a shelf.
- Corrective Action
Connect two ports to different modules to provide redundancy.
- Syslog Message
There are two ports cabled from node %s to top module (A) on Shelf with SN %s. One of these cables should be removed.
- Parameters
