ONTAP EMS reference
wafl.analytics events
wafl.analytics EMS events occur when ONTAP encounters issues associated with file system analytics database inconsistencies or operations.
wafl.analytics.air.uh
Severity
ALERT
This message occurs when the system detects an inconsistency in the file system analytics database. As a consequence, file system analytics has been disabled.
Corrective Action
Turn file system analytics on again for the volume to initiate new consistent analytics.
Syslog Message
The system detected an inconsistency in the file system analytics database associated with volume %s:%s.
vserveruuid (STRING): Universal Unique ID (UUID) of the volume's Vserver.
volname (STRING): Volume name.
wafl.analytics.init.fail
Severity
ALERT
This message occurs when a volume fails to have a file system analytics database initialized.
Corrective Action
Disable then re-enable file system analytics for the volume. If problems persist or further assistance is needed, contact NetApp technical support.
Syslog Message
Failed to initialize a file system analytics database for volume %s:%s, %s.
error (STRING): Error message.
wafl.analytics.recover
Severity
ALERT
This message occurs when a volume fails to recover the File System Analytics state after failing to start the initialization scanner. As a consequence, File System Analytics information might be unavailable or might not accurately reflect the volume's content.
Corrective Action
Use the "volume analytics off" command to disable File System Analytics on the volume, and then use the "volume analytics on" command to enable File System Analytics. If problems persist or further assistance is needed, contact NetApp technical support.
Syslog Message
The File System Analytics state for volume %s%s was not recovered after the initialization scanner failed to start. Reason: %s.
wafl.analytics.rescan
Severity
ALERT
This message occurs when the system detects an inconsistency in the file system analytics database. As a consequence, file system analytics information might be unavailable or might not accurately reflect the volume's content.
Corrective Action
Turn file system analytics off and then on again for the volume. If problems persist or further assistance is needed, contact NetApp technical support.
Syslog Message
wafl.analytics.scan.fail
Severity
ALERT
This message occurs when the "volume analytics on" command fails due to an internal error.
Corrective Action
Resolve the error if possible. Disable file system analytics using the "volume analytics off" command and then re-enable file system analytics using the "volume analytics on" command. If problems persist or further assistance is needed, contact NetApp technical support.
Syslog Message
File system analytics scan failed for volume "%s:%s. Error: %s".
wafl.analytics.tz.changed
Severity
ERROR
This message occurs when the system timezone is changed while file system analytics is enabled on the node. As a consequence, file system analytics information might not accurately reflect the volume's content.
Corrective Action
Use the "volume analytics show -state on" command to find the volumes with file system analytics enabled, then use the "volume analytics off" and "volume analytics on" commands for each volume where file system analytics is enabled.
Syslog Message
The system timezone has been changed while file system analytics is enabled.
(None).
