ONTAP EMS reference
wafl.analytics events
wafl.analytics.air.uh
Severity
ALERT
This message occurs when the system detects an inconsistency in the file system analytics database. As a consequence, file system analytics has been disabled.
Corrective Action
Turn file system analytics on again for the volume to initiate new consistent analytics.
Syslog Message
The system detected an inconsistency in the file system analytics database associated with volume %s:%s.
vserveruuid (STRING): Universal Unique ID (UUID) of the volume's Vserver.
volname (STRING): Volume name.
wafl.analytics.discardNotOk
Severity
ALERT
This message occurs when the analytics subsystem discards a pending reminder work request due to an internal error. Repeated instances of this message indicate low accuracy of the analytics data reported for the volume.
Corrective Action
Taking the volume offline and bringing it back online might resolve the issue. Find the name of the Vserver and volume using the "volume show -dsid <dsid>" command. Take the volume offline using the "volume offline" command, and then bring it back online by using the "volume online" command. If the problem persists or further assistance is needed, contact NetApp technical support.
Syslog Message
An analytics reminder work request was discarded due to an unexpected error. The corresponding volume dsid is "%lu". The error returned was: %s
dsid (LONGINT): Dsid of the volume affected by the discarded reminder work request.
error (STRING): Error returned by reminder processing.
wafl.analytics.enterOverload
Severity
NOTICE
This message occurs when the analytics subsystem is not keeping up with the amount of work being generated by the system. This could be an indication of an overloaded system in general. Analytics accounting might lag, and reported data might not be as current as the data that the subsystem usually reports.
Corrective Action
The system should attempt to resolve the problems by itself. If problems persist or further assistance is needed, contact NetApp technical support.
Syslog Message
The analytics subsystem is not keeping up with the amount of work being generated by the system.
(None).
wafl.analytics.exitOverload
Severity
NOTICE
This message occurs when the analytics subsystem is performing normally and has caught up with its pending work.
Corrective Action
(None).
Syslog Message
The analytics subsystem is performing normally.
(None).
wafl.analytics.init.fail
Severity
ALERT
This message occurs when a volume fails to have a file system analytics database initialized.
Corrective Action
Disable then re-enable file system analytics for the volume. If problems persist or further assistance is needed, contact NetApp technical support.
Syslog Message
Failed to initialize a file system analytics database for volume %s:%s, %s.
error (STRING): Error message.
wafl.analytics.languishing
Severity
ALERT
This message occurs when the analytics subsystem is unable to make progress, which could be an indication of an unhealthy node or a larger systemic issue.
Corrective Action
Syslog Message
The analytics subsystem has languished for more than 900 seconds.
(None).
wafl.analytics.offErr
Severity
ALERT
This message occurs when file system analytics fails to turn off. This can cause incorrect file system analytics results.
Corrective Action
Use the "volume show -dsid <dsid>" command to find the volume on which file system analytics failed to turn off, and then use the "volume analytics off" command to attempt to turn off file system analytics. If problems persist or further assistance is needed, contact NetApp technical support.
Syslog Message
File system analytics failed to turn off on the volume with DSID "%lu". Error: %d. Context: %s.
dsid (LONGINT): Data Set ID (DSID) of the volume on which file system analytics failed to turn off.
error (INT): Error code returned when file system analytics failed to turn off.
context (STRING): Which operation attempted to turn off the file system analytics.
wafl.analytics.recover
Severity
ALERT
This message occurs when a volume fails to recover the File System Analytics state after failing to start the initialization scanner. As a consequence, File System Analytics information might be unavailable or might not accurately reflect the volume's content.
Corrective Action
Use the "volume analytics off" command to disable File System Analytics on the volume, and then use the "volume analytics on" command to enable File System Analytics. If problems persist or further assistance is needed, contact NetApp technical support.
Syslog Message
The File System Analytics state for volume DSID (%lu) was not recovered after the initialization scanner failed to start. Reason: %s.
dsid (LONGINT): Unique identifier (DSID) of the volume.
wafl.analytics.rescan
Severity
ALERT
This message occurs when the system detects an inconsistency in the file system analytics database. As a consequence, file system analytics information might be unavailable or might not accurately reflect the volume's content.
Corrective Action
Turn file system analytics off and then on again for the volume. If problems persist or further assistance is needed, contact NetApp technical support.
Syslog Message
wafl.analytics.scan.fail
Severity
ALERT
This message occurs when the "volume analytics on" command fails due to an internal error.
Corrective Action
Resolve the error if possible. Disable file system analytics using the "volume analytics off" command and then re-enable file system analytics using the "volume analytics on" command. If problems persist or further assistance is needed, contact NetApp technical support.
Syslog Message
File system analytics scan failed for volume "%s:%s. Error: %s".
wafl.analytics.state.change
Severity
NOTICE
This message occurs when the file system analytics state has been changed on a volume.
Corrective Action
(None).
Syslog Message
The file system analytics state of volume "%s:%s" (DSID: "%lu") has changed to "%s". Reason: %s. Rulegen: %lu.
vserveruuid (STRING): Universal Unique ID (UUID) of the volume's storage VM (SVM).
state (STRING): File system analytics state: on or off.
reason (STRING): The reason that the file system analytics state was changed.
rulegen (LONGINT): File system analytics rules generation number.
wafl.analytics.tooMuchMemory
Severity
ALERT
This message occurs when the analytics subsystem has an excessive amount of pending work, causing memory usage to be higher than expected.
Corrective Action
Syslog Message
Reminder table size is %lu, which is above the design limit of 500MB.
tablesize (LONGINT): Current size of analytics subsystem reminder table.
wafl.analytics.tz.changed
Severity
ERROR
This message occurs when the system timezone is changed while file system analytics is enabled on the node. As a consequence, file system analytics information might not accurately reflect the volume's content.
Corrective Action
Use the "volume analytics show -state on" command to find the volumes with file system analytics enabled, then use the "volume analytics off" and "volume analytics on" commands for each volume where file system analytics is enabled.
Syslog Message
The system timezone has been changed while file system analytics is enabled.
(None).
