ONTAP EMS reference
sas.reset events
sas.reset EMS events occur when ONTAP encounters issues associated with SAS expander resets.
sas.reset.exp.discovery.resp
Severity
NOTICE
This message occurs when SAS adapter driver resets the expander because of failure status of discovery response.
Corrective Action
If this message is infrequent, no action is needed. Otherwise, contact NetApp technical support.
Syslog Message
SAS adapter [%s]: Incorrect status in discovery response, resetting expander: %s
adapterName (STRING): Name of the associated SAS adapter.
expanderName (STRING): Name of the expander being reset.
sas.reset.exp.open.dest
Severity
NOTICE
This message occurs when SAS adapter driver resets the expander because open frames are recieving excessive no/bad destination status.
Corrective Action
Syslog Message
SAS adapter [%s]: Excessive open no/bad destination status, resetting expander: %s
sas.reset.exp.open.to
Severity
NOTICE
This message occurs when SAS adapter driver resets the expander because of excessive open timeouts.
Corrective Action
Syslog Message
SAS adapter [%s]: Excessive open timeouts occured, resetting expander: %s
sas.reset.exp.smp
Severity
NOTICE
This message occurs when SAS adapter driver resets the expander because of excessive SMP failures.
Corrective Action
Syslog Message
SAS adapter [%s]: Excessive SMP failures occured, resetting expander: %s
