sas.reset events
sas.reset EMS events occur when ONTAP encounters issues associated with SAS expander resets.
sas.reset.exp.discovery.resp
- Severity
NOTICE
- Description
This message occurs when SAS adapter driver resets the expander because of failure status of discovery response.
- Corrective Action
If this message is infrequent, no action is needed. Otherwise, contact NetApp technical support.
- Syslog Message
SAS adapter [%s]: Incorrect status in discovery response, resetting expander: %s
- Parameters
adapterName (STRING): Name of the associated SAS adapter.
expanderName (STRING): Name of the expander being reset.
sas.reset.exp.open.dest
- Severity
NOTICE
- Description
This message occurs when SAS adapter driver resets the expander because open frames are recieving excessive no/bad destination status.
- Corrective Action
- Syslog Message
SAS adapter [%s]: Excessive open no/bad destination status, resetting expander: %s
- Parameters
sas.reset.exp.open.to
- Severity
NOTICE
- Description
This message occurs when SAS adapter driver resets the expander because of excessive open timeouts.
- Corrective Action
- Syslog Message
SAS adapter [%s]: Excessive open timeouts occured, resetting expander: %s
- Parameters
sas.reset.exp.smp
- Severity
NOTICE
- Description
This message occurs when SAS adapter driver resets the expander because of excessive SMP failures.
- Corrective Action
- Syslog Message
SAS adapter [%s]: Excessive SMP failures occured, resetting expander: %s
- Parameters
