pubsub.kernel events
pubsub.kernel EMS events occur when ONTAP encounters issues associated with kernel publish-subscribe (pubsub) operations.
pubsub.kernel.flow.control.enabled
- Deprecated
This event is deprecated as of 9.10.0.
- Severity
ERROR
- Description
This message will not be published as flow control is enabled on kernel pubsub.
- Corrective Action
Check the network connectivity to the broker and ensure the broker is running properly.
- Syslog Message
Kernel pubsub failed to send message with topic %s, object %s, object UUID %s and operation %s. Flow control is enabled.
- Parameters
topic (STRING): Topic of the message.
object (STRING): Object of the message.
object_uuid (STRING): Object UUID of the message.
operation (STRING): Operation of the message.
pubsub.kernel.send.msg.failed
- Deprecated
- Severity
ERROR
- Description
This message occurs when kernel pubsub fails to send a message to the broker.
- Corrective Action
- Syslog Message
Kernel pubsub failed to send message with topic %s, object %s, object UUID %s, operation %s, and error code %d.
- Parameters
error_code (INT): Error code associated with the failure.
