ONTAP EMS reference
nvme.fw events
nvme.fw.activate.complete
Severity
NOTICE
This message occurs when new firmware has been successfully activated on the drive and running normally.
Corrective Action
(None).
Syslog Message
NVMe caching module in physical slot %s with serial number %s, and model number %s successfully replaced firmware version %s with %s in firmware slot %u.
slot_subslot (STRING): PCI slot of the NVMe device.
serial (STRING): Serial number of the controller.
model (STRING): Model number of the controller.
old (STRING): Version of firmware that has been replaced.
new (STRING): Version of firmware that was activated.
fw_slot (INT): Firmware slot that the new version was programmed to.
reset (INT): An indication on whether the device had to be reset or not in order to activate the firmware.
nvme.fw.activate.failed
Severity
ERROR
This message occurs when there was an issue while activating the new firmware on the the NVMe drive. The caching module will continue normal operation with obsolete firmware.
Corrective Action
The caching module is still completely functional, but it is running with obsolete firmware. Contact NetApp technical support for alternative solutions.
Syslog Message
NVMe caching module in slot %s with serial number %s and model number %s failed to activate firmware. Error code: 0x%llx.
code (LONGINTHEX): Internal error code.
nvme.fw.program.failed
Severity
ERROR
This message occurs when there was an issue while downloading new firmware to the NVMe drive. The caching module will continue normal operation with obsolete firmware.
Corrective Action
The caching module is still completely functional however it is running with obsolete firmware. Contact NetApp technical support for alternative solutions.
Syslog Message
NVMe caching module in slot %s with serial number %s, and model number %s failed to download firmware version %s to the drive with error code 0x%llx.
version (STRING): Version of firmware attempted to download.
