wafl.svo events
wafl.svo.checkFailed
- Severity
NOTICE
 - Description
This event is generated if a write to a svo enabled volume fails to pass a check
 - Corrective Action
(None).
 - Syslog Message
 - SnapValidator: Validation error %s
v:%s vol:%s%s%s inode:%d length:%d Offset: %lld
 - Parameters
error (STRING): error that occurred when validating the write
version (STRING): string to describe version of oracle tests that were run
vol (STRING): The volume name
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
inode (INT): The inode number of the file which was being written
length (INT): The length of the invalid write
offset (LONGINT): The offset into the inode where the write sent. Note for Luns this will be to the main inode, and does not include space used by prefix streams.
wafl.svo.optionSet
- Severity
INFORMATIONAL
 - Description
This event is generated when a SnapValidator option is set on a volume
 - Corrective Action
(None).
 - Syslog Message
SnapValidator option '%s' set to '%s' on volume '%s%s'
 - Parameters
opname (STRING): name of the option being set
opvalue (STRING): value of the option being set
vol (STRING): name of the volume the option is being set on
