ONTAP EMS reference
wafl.svo events
wafl.svo EMS events occur when ONTAP encounters issues associated with SnapValidator for Oracle (svo) operations.
wafl.svo.checkFailed
Severity
NOTICE
This event is generated if a write to a svo enabled volume fails to pass a check
Corrective Action
(None).
Syslog Message
SnapValidator: Validation error %s
v:%s vol:%s%s%s inode:%d length:%d Offset: %lld
error (STRING): error that occurred when validating the write
version (STRING): string to describe version of oracle tests that were run
vol (STRING): The volume name
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
inode (INT): The inode number of the file which was being written
length (INT): The length of the invalid write
offset (LONGINT): The offset into the inode where the write sent. Note for Luns this will be to the main inode, and does not include space used by prefix streams.
wafl.svo.optionSet
Severity
INFORMATIONAL
This event is generated when a SnapValidator option is set on a volume
Corrective Action
(None).
Syslog Message
SnapValidator option '%s' set to '%s' on volume '%s%s'
opname (STRING): name of the option being set
opvalue (STRING): value of the option being set
vol (STRING): name of the volume the option is being set on
