config.sameha events
config.sameha EMS events occur when a disk is multipathed to the same host adapter.
config.sameHA
- Severity
ERROR
- Description
This message occurs when a disk is multipathed to the same host adapter. The second disk interface should be attached to a different host adapter.
- Corrective Action
Move one of the connections attaching the disk shelf to a different host adapter.
- Syslog Message
Disk %s and other disks attached to the same port are dual-attached to the same adapter. For improved availability you should dual-attach them to separate adapters.
- Parameters
disk (STRING): Name of the disk.
