ONTAP EMS reference
nvmeof.cabling events
nvmeof.cabling.clear
Severity
NOTICE
This message occurs when all of the cabling issues to the shelf have been corrected.
Corrective Action
(None).
Syslog Message
The storage cabling issues on node "%s" have been corrected.
node_name (STRING): Node name connected to the cable.
nvmeof.cabling.error
Severity
ERROR
This message occurs when there are errors with the cabling to the shelf.
Corrective Action
Run the "storage check-cables" node shell command to list the errors. Follow the cabling guide to correct the issues.
Syslog Message
There is a storage cabling issue on node "%s". Run the "storage check-cables" node shell command to list the errors.
