The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nvmeof.cabling events
Creating your file...
Your file is ready
nvmeof.cabling.clear
- Severity
NOTICE
- Description
This message occurs when all of the cabling issues to the shelf have been corrected.
- Corrective Action
(None).
- Syslog Message
The storage cabling issues on node "%s" have been corrected.
- Parameters
node_name (STRING): Node name connected to the cable.
nvmeof.cabling.error
- Severity
ERROR
- Description
This message occurs when there are errors with the cabling to the shelf.
- Corrective Action
Run the "storage check-cables" node shell command to list the errors. Follow the cabling guide to correct the issues.
- Syslog Message
There is a storage cabling issue on node "%s". Run the "storage check-cables" node shell command to list the errors.
- Parameters
