nvmeof.cabling events
Creating your file...
Your file is ready
nvmeof.cabling.clear
- Severity
NOTICE
- Description
This message occurs when all of the cabling issues to the shelf have been corrected.
- Corrective Action
(None).
- Syslog Message
The storage cabling issues on node "%s" have been corrected.
- Parameters
node_name (STRING): Node name connected to the cable.
nvmeof.cabling.error
- Severity
ERROR
- Description
This message occurs when there are errors with the cabling to the shelf.
- Corrective Action
Run the "storage check-cables" node shell command to list the errors. Follow the cabling guide to correct the issues.
- Syslog Message
There is a storage cabling issue on node "%s". Run the "storage check-cables" node shell command to list the errors.
- Parameters
