      nvmeof.cabling events
nvmeof.cabling.clear
- Severity
NOTICE
 - Description
This message occurs when all of the cabling issues to the shelf have been corrected.
 - Corrective Action
(None).
 - Syslog Message
The storage cabling issues on node "%s" have been corrected.
 - Parameters
node_name (STRING): Node name connected to the cable.
nvmeof.cabling.error
- Severity
ERROR
 - Description
This message occurs when there are errors with the cabling to the shelf.
 - Corrective Action
Run the "storage check-cables" node shell command to list the errors. Follow the cabling guide to correct the issues.
 - Syslog Message
There is a storage cabling issue on node "%s". Run the "storage check-cables" node shell command to list the errors.
 - Parameters
